ANR-2010-BLAN-0219-01
Logo Cutter project
CUTTER
Quality driven Object-Oriented Software Remodularization
CUTTER is a Basic Research project that addresses the problems of object-oriented system (re-)modularization by developing, combining, and evaluating new techniques for analyzing and modularizing code. In particular, it will: (i) use concurrently and collaboratively four package decomposition techniques; and (ii) take into account different levels of abstractions (packages, classes).
Calendar
The project will will last 42 months. It started officially on March 1st, 2011 and will end on August 31, 2014
RMOD LIRMM-D'OC-APR
Project Links
| GForge | Wiki | SVN |
You must login on GForge and be member of the project to make changes in these pages.
